New Version of SmartSDR for MAC
Mike-VA3MW
What’s new in version 2.0.05 Nov 7, 2021
This update includes the following changes and fixes:
- An issue with the FT4 mode has been fixed
- An issue with the mouse pointer Icon not changing has been fixed
- The App is now a native M1 App and compatible to Intel Macs too
- Some changes were made for macOS 12 Monterey
- A new option “Worked before” on same Band has been added
- Recordings can now also be re-transmitted
- An overlapping slice flag can now be selected correctly
- To connect a CW-Key or Foot-Switch, the App no longer needs the ftdi D2XX drivers (see manual for details)
- An issue with the call-sign database has been fixed
- An issue in the DX-Cluster tool when using Telnet clusters has been fixed
- A bug in PSKReporter was fixed
- The LOTW Certificate signing now uses the local Keychain. You may be prompted for your local password for keychain access.
- The range for the Bandwidth MIDI assignment has been increased
- In CWX, when double-clicking on a list entry, the text will be repeated
2
Love…thank you Marcus.0
.0
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 269 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
