ANBLER LED POWER SWITCH RADIO IS OFF
Good Evening Everyone,
I have seen the other posts related to the Amber LED Power switch. My power switch, on my FLEX 6400 v3.2.39, is Amber when the radio is off. I don't think I have the GPSDO option installed. The Status shows as Not Present in the GPS configuration tab in Radio Setup. The "Remote On" is Disabled in the Radio Information settings. I have just begun to notice this. Any ideas from the group?
Mark
KK2L
Hi Mark, I would do a profile export, then do a factory reset, then re-import your profiles.
If that does not help, go to the radio setup and turn on then off the GPS option to see if that resolves it.
If neither of these suggestions work, submit a help desk ticket. I am sure Flex Support has seen this before and will be able to help.
Hi Len,
Thank you for the suggestion. Amber light persists after Factory Reset. I submitted a help desk ticket.
Mark
KK2L
It sounds like you told the Radio you have a GPSDO installed but you don't. Go to the GPS screen and disable the GPS. I'm not in front of a radio, so can't get you the exact steps.
- 375 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
