radio beeps every time the VHF radio transmissions
I have a flex 6500 in a rack with various other HF radios for example 2 CODAN Envoys, and 2 Motorola VHF radios. Each time the VHF radios transmit, the flex beeps but shows no error codes on the screen. They are all very well grounded and I have placed type 31 ferrite beads on all of the RF connections and power and data lines. The error continues, could there be a hardware issue in the flex as I would really like to keep it operational in the environment but it seems to be the only radio having a rejection issue.
Rodney Warner
Region 6 Director, U.S. Army Mars
512 – 496 – 4301
Try the ferrite on the VHF lines too.
Bill W9JJB
Hi Rodney. It is unlikely to be a hardware problem with the radio. More likely is RF getting in some other way.
I would start with the speakers. Do you have powered speakers plugged into the back of the radio? If so, unplug them and listen to audio using PC audio. If the beeping goes away, then you can try ferrites on the speaker signal lines and power leads.
If that is not it, start disconnecting things (keys, mics, headphones, etc) to see if you can find the line where the RF is getting in. I would even disconnect any HF antennas in case there is some common mode interference or plain old signal overload coming in that way.
You might also want to try some mix 43 ferrites to stop VHF. Mix 31 is more for HF. Even though your issue is happening to an HF radio, it sounds like it is triggered by VHF signals.
Let us know how it goes. There are probably many more things to try that I am not thinking of at this point.
I would also suggest the power leads, esp if common to multiple radios
I can't think of a single thing that causes a Beep. Are you sure it is coming from the Flex radio? Does it happen if the radio is off?
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
