Q5 Signal Transverter on slice A and HF in Slice B
Hi guys,
I want an information, I have a Q5 txrv for 144 but when I open an other Slice for RX on HF my txrv not work on slice A, not possible use it during slice B rx on HF?
Best regards
IZ7AUH
    Which model radio?
    If it is a 6300, 6400, or 6500, you are not able to do that as you only have 1 Spectral Capture Unit.
    If you want to do HF at the same time you need a 6600 or a 6700.
  • iz7auh
    iz7auh Member ✭✭
    edited December 2021
    Tnx fro your reply, I cmf I have an 6400....
