100w through PGXL
Adde Tjernberg
Is it ok to run 100w through the PGXL when it is in Standby-mode?
73 de Adde SM0SHG
Standby mode is basically a bypass input to the output there is no problem running 100 watts. This is true of most any power amps in standby mode. You can even use your built in tuner, when in amp standby, if you have one, to tune the antenna. Basically other then some switches (relays) it is like a piece of wire. Most likely the SWR and output monitoring is still done, also.
2
I do it all the time. I'm not the official responder on this but I've seen no ill results.
I see no problem if there was, it would show up in BOLD print in the getting started manual, But I to am not the official responder.
2
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
