Show PGXL on Maestro
I have looked over the manual on the PGXL as well as other places, but I do not see how to have the PGXL controls show on the Maestro. I am trying to do this on my 6600M and probably the stand alone Maestro (I have not tried that yet).
I thought you could control and see the amp on the Maestro, but do not see how to do that. Works great on SSDR.
73, John K0TG
  • David Decoons, wo2x
    Once the amp is set up to communicate to the radio and rear power of amp is on you should see a greyed out AMP indication next to the power setting in top center of radio display. Tapping on that will turn the amp from standby to operate. If you click on meters in bottom right of display it will bring up meters on right side of display. You can click the + to add meters. Tap a meter to step through each type of meter available.
  • John K0TG
    John K0TG Member ✭✭
    I thought it would find the radio. Looks like all is well today as I see everything now. Not sure why I did not see it before, but all is well now.
    Thanks es 73, John K0TG
