Cannot save TGXL configuration
I was off line for a few weeks due to my home renovation.
When connected everything back at my shack, i found that my TGXL is no longer shows the Antenna number, it still follow the band changes from 6600.
I tried to update from ver 1.1.1 to 1.6 without success.
When I am entering IP address of AG2x8, TGXL cannot save it in both versions 1.1.1 and 1.6.
Any idea how to solve it?
Thanks, Sergey
While I am waiting for a helpdesk response, can someone share the same image as above from your setup?
I suspect that something with IP range...
Looks to me like your trying to connect to the wrong address.
The GSD I think is for something else not for the Tuner to talk to.
I run my Antenna Genius using a static IP as MY preferred way to do it.
hope this helps
Thank you Bret,
I figured it out, i forgot that i have to take IP address from AG "Device Information" window and not from "Configure Device" window.
Sergey
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
