Expert 1.5FA Overdrive Parametric Settings
Terry Erlacher
Terry Erlacher Member ✭✭
My Flex 6700 power input to the Expert 1.5FA is 20 watts. The Parametric Settings per page 40 of the Expert 1.5FA manual are 25 Low Power 30 Mid Power and 40 High Power. In CW Mode I am getting an Overdrive Alarm on Low and Mid Power amp settings. I do not get an overdrive alarm on High Power. On SSB Phone I do not have an overdrive alarm for the 3 amplifier power settings. The antenna is a ground mounted Hustler 6BTV with 60 radials approximately 30 feet from the shack. Looking for advise on resolving the CW Overdrive alarms when I desire to run low or mid power. I have seen posts on DDUTIL to manage power settings per band, but have not tried the software. 73, Terry KC4DV
Best Answers
  • Wayne VK4ACN
    Wayne VK4ACN Member ✭✭✭
    edited December 2021 Answer ✓
    My Spe 1.5 manual doesnt show any power drive settings for the Flex.. I cant see what you are meaning. I thought you started on low power, and set the drive at a low level eg: 8 watts and worked up from there. If you are getting an overdrive alarm, you need to reduce the drive power. I use the SPE app on the pc to control the amp, and drive levels. I dont use ddutil
  • David Decoons, wo2x
    Answer ✓
    Parametric EQ settings will not resolve overdriving the 1.3k amp.
    Set you TX Band settings table properly.
  • Erik Carling EI4KF
    The parametric settings have nothing to do with EQ. The manual refers to " you must set a parametric value having the format “[PC=****]” (where **** is a numerical value having a range from 000 to 100 which represents the transceiver’s power output expressed in percentage)." Note it is as a percentage and, in my experience with the 1.5, is quite inaccurate. Adjust this upwards as Wayne suggests in a constant carrier mode. If you operate all bands this is a lot of settings but once done you should be good to go for all modes. If not, which did happen to me, SPE will assist with internal ALC calibration.
  • Terry Erlacher
    For CW I lowered the input drive to 4 watts for Amp Low 8 watts Amp Mid and 12 watts Amp High. these setting are giving me 500 watts on Low, 1000 watts on Mid and 1500 watts on High. I set the Parametric parameters to 10, 15 and 25. Amazing how little power CW takes to drive the Expert 1.5FA Amplifier. Thanks Everyone for your help. 73 and Happy Holidays de Terry KC4DV
    Ok you are talking parameters in the amp and not radio. When people discuss “parametric” it usually has to do with parametric type of audio equalizers.
    be careful on drive power. I understand there have been quite a few cases where the LDMOS device was damaged by too much drive and SPE America would not honor warranty. Err on the side of caution.
