No Front Speaker audio.
Hi, i have a Flex-6600M, but since some time ago i do not have audio from the front speaker. No audio on Run or smartsdr modes.
I have the front speaker enabled with 100% volume, but no audio.
Could be a hardware problem?
  • Hal Massey
    Hal Massey Member ✭✭
    There are a number of ways to mute and unmute audio and route it. Check the master audio menu. Also the front knobs can be pushed to mute and un-mute audio. Flex also has an excellent hardware user manual online.
    If you have confirmed thise are set correctly
    Then, the radio might be confused and require resetting.
