Flexradio 6700 and Acom 700s amplifier
Bought and made several USB to serial cables to make a CAT connection, but nothing will work. Changing the frequency on the Flexradio wil not result in changing the frequency on the Acom amplifier.
I've seen the movies on the internet how to connect and config the amp and the flex, RS232, BCD etc. they don's work. The usb cable works fine according the flex (HI),
My question: does anyone have a configuration above and does the CAT connection work?
PSE tell me how.
I use a 600s and assume the 700s would be similar. I have followed this procedure:
Be sure to use a FDMI USB to serial converter!
[{"insert":"Mark, I have seen this video but it does not work. \n\n"}]0
I'm running a 6600M and CAT controlling my Acom 700S which in turn controls my Acom 04AT tuner. Let me know how I can help.0
Problem is solved, tested a new cable with different PIN connections0
Good to see the problem was resolved with a new cable wired to the right pins
Is it possible for the 6600 radio to power the ACOM amp on and off ? via the RS232 port I guess as the 6600 radio is turned on and off the ACOM amp also powers on and off / or is there another way
I have tried ACOM Director Plus and it can turn the ACOM amp off but not back on
Paul M0AIA
Paul, checkout Acom Director Plus software. A Flex was not designed to be a computer providing overall control of other devices. The Flex architecture expects some other computer running Windows, MacOS, etc. to control the Flex and other station accessories...0
Hi,
I have a Flex 6500 and and Acom 700S, plus the O40T ATU / antenna switch. In reply to the above comments, I have found the Acom controller software works much better than director for the 700S
I noticed recently the atu tune function no longer works as it should, has anyone else had similar issues.
In order to get the Acom ATU to tune, I have to set the cat feature to off in the amplifier, and then tune manually.
M0MS
Hello everyone, I work with a Flex 6400, an Acom 1200s and the 04 tuner. The combination 6400 and Acom 1200s works very well with the CAT interface! There were problems when connecting the tuner! When controlling the tuner via the Acom 1200, the 6400 was controlled directly. The flex was set to 30W and went on the air...without power! After that, any frequency was set on the TX and the Smart SDR software froze. A restart has not been possible since then :-( Does anyone have an idea 730
Hi!
@Luis You have to perform a factory reset with the Flexradio.
I went into the same trouble. Only resetting to factory defaults made my Flex work again.
Andy, DL6CQ0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
