Drop Out
I have a 6700, PGXL & Ant. Genius --- When I Xmit on 20M using High Pwr everything drops out.
This only happens on 20M all other bands no problem.
I have added ferrites to everything ie; PC pwe, Ethernet, all ham equipment Enet & pwr.
Any suggestions would be greatly appreciated.
Hi Dan, RFI can be tricky to figure out. I usually start by disconnecting stuff to see if I can figure out where it is getting in. In my most recent case, it was coming in on my keyer lines. My paddles, straight key and key out lines all had to be disconnected, and now I have no issues on any band, any power.
Now that I have the culprits identified, I will add ferrites (and maybe additional bypass caps) to them when they arrive from Palomar. Sometimes the RF path is not at all obvious. I have had cases where non-ham equipment was part of the path, and when disconnected from power, everything else started working properly again. If you don't find it easily, start looking at other gear.
Sometimes, if your antenna is very close (e.g. attic ant), snap on ferrites don't do any good. You may need to get a donut ferrite and wrap several turns of the offending cable through it. Unfortunately, there is no one, easy answer to RFI...
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
