TGXL power supply
I received my Tuner the other day and it is great!! I have a question however...I power my 6700 from a PowerWerks 30 amp supply and turn it on/off remotely then remotely turn on the 6700 with the remote turn on feature..... I thought I would power the Tuner off the same power supply so that it came on when I used the 6700.. the problem is that as soon as I turn on the power supply and the 6700 is still off, the power supply indicates it is drawing 3 amps and the fan in the supply begins to race but the tuner does not turn on... if I pull the power cord to the Tuner the fan instantly stops and the power meter on the supply indicates zero and then if I re-insert the power cord the tuner comes on and the fan stops.. everything is normal.. Any ideas what causes this???
Tnx AH0U
  • W2PP
    W2PP Member ✭✭✭
    It sounds like you need the latest hardware update in the TGXL
    I recommend you open a help desk ticket
    I have this update and I now virtually never see that condition
    Peter
