drive error dax - Windows 11
Hello everyone,
I am under win 11, I have flex version 2.7.6, flex 6700, I have a "drive error" problem at the "DAX" level, which prevents having waterfal and the wide graph of wsjtx, also not of TX, see photo, how to recover the good drive, I removed, the program of the flex and xsjtx and replaced by the new ones
I also removed the "cat" and replaced, with no results, who can help me, thanks
ON5PO, janny
I have converted this to a helpdesk ticket.
Hello everyone, I found a solution to recover the factory program from the flex, the drivers are ok now, I still have a problem which I do not believe that the flex is in error, it is on the side of wsjtx, when I want to "tune" or eneble tx no peak at the spectrum no modulation, I have the reception at different waterfal, the tx commende amplify and flex, without modulation,
who would have the solution, thank you
73 on5po, Janny
hello everyone,
I found the solution very well explained on another post, everything seems to work now, thank you for reading me
on5po, Janny
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
