Dashboard items missing on W11
I am using Windows 11(having upgraded from Windows 10) and SmartSDR v 3.2.37. I have noticed that my dashboard is now missing the apps down the right hand side of the page that allow me to tune the antenna, etc. I think there were about 5 or 6 apps (that's what I am calling them but they are probably just little windows/functions). I can't find how to get them back.
I realize this could be because I am still using v3.2.37 and not the latest 3.2.39, but my club's Flex 6400 is still using that older version. They are due to upgrade shortly, so do I have to wait for the upgrade to put things right or is there a way I can reclaim the missing functions in the meantime?
Welcome!
  • Member, Super Elmer Moderator
    Hi Grant, Do you at least have this little arrow? If so, just click it and the functions will reappear.
    Also, check to be sure that your SmartSDR window is not just moved left slightly taking the functions out of your view.
  • Member ✭✭
    Hi Len, Yes I have that little arrow etc but that only brings into view the items that normally reside on the left of the dashboard. My issue is how to get the items that normally reside on the right of the page back. Now it's possible they aren't needed but if that's the case how do I tune the antenna or want to activate VOX?
    Hi Grant, Sorry, I misunderstood. Try this icon in the lower left. It turns on and off the control panel.
  • Member ✭✭
    Thanks Len, I'll give that a try.
  • Member ✭✭
    Hi Len, Tried what you suggested - works perfectly now. Thanks a ton.
