6400M DAX Question
Craig Kolk
Running a 6400M with no PC connected. I am connected to my network. Running SSB.
What should the DAX setting be set to?
Thank you,
Craig
W1ZN
Best Answers
Unless you are running a digital app on a PC, or are running a logging program that uses DAX to output audio, just leave DAX off.
As above, DAX is used to connect the flex audio to other programs for a variety of purposes, for example WSJT.
In your case with SSB, no DAX connection is required. That is only for Digital mode operations (or similar).
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
