Is it possible to connect two ciro Mazzoni loops to a Flexradio 6700
myTech61
Member ✭
Building a remote-controlled station, I won't add two Ciro Mazzoni loops (Baby & Midi loop) to my Flex radio 6700 as ANT1 & ANT2. How can I now use the auto-tune on the right antenna (how to define which antenna has to be tuned). Any suggestions?
Yes, you can.
You will need to USB/RS232 cables connected to the radio and then to each loops controllers.
You would select 2 different sources. https://www.flexradio.com/documentation/usb-cable-interface-guide-pdf/
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
