SO2R PTT handling
Hi everyone,
I have a flex 6700, with two sets of external BPFs, an SO2R antenna switch and two amplifiers. I have SO2R working just fine without the amps. I can TX on one slice whilst listening to a different band on the second. When I add the amps, one keyed by the TX1 RCA and the other by the TX2 RCA, transmitting on band A mutes band B as both amplifiers are put into TX.
I know that I can dedicate the TX RCAs to specific bands, but I wanted to get full flexibility to operate any band on either slice. SO2R mashes my brain so much that I dont want to have any more thinking to do :)
So, how do I tell smartsdr to use TX1 RCA for Slice A and TX2 RCA for slice B? This must be out there, but I cant find it!
Steve, M0BPQ
Best Answers
Hi Steve,
Yes you can :-)
It is not well explained anywhere in the Flex documentation available unfortunately, but you can use as a base the document: https://www.flexradio.com/documentation/flex-6700-so2r-configuration-n1mm/
The way I do it is creating 2 TX profiles. I assign TX profile "SO2R TX1" to Slice A and then I click on RCA TX1 on all bands, then save TX profile. Then I open a new panadapter with slice B and I assign TX profile "SO2R TX2" and then I click on RCA TX2 on all bands, then save TX profile.
No need for anything else.
The issue here is that each time you change band in any of the slices-panadapters, the antenna selection is not saved so it´s a bit frustrating. Fortunately, when using the Flex in SO2R together with N1MM+, if you switch bands from N1MM+ using OTRSP, the antenna selection remains!
It would be nice if Flex could correct this in future releases, leaving antenna selection unchanged when using SO2R profiles, for daily use without N1MM...
73! Jon
Jon's answer is soooo much better than mine, that I deleted mine. I totally blanked on doing that.
Thanks Jon
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
