Flex 6400M wont receive in WSJT-X Fox Hound mode
W0QC
W0QC Member
edited October 2021 in Third-Party Software
Hello:
My friends Flex 6400M wont receive in the Band activity Screen when in Fox Hound Mode
Transmits fine but no receive signals. Ant Ideas what's wrong?
    It is hard to tell with limited information and there about a dozen configuration things that could impact this, a few of them with WSJTx.
    My 'guess' is that his WSJTx Audio Receive bandwidth is not seeing the entire audio passband. He can see his audio receive passband by looking at WSJTx's waterfall.
    Screen shots of his problem will tell more of the story.
  • W0QC
    W0QC Member
    The passband is set at 3kc and it receives fine when not in Fox Hound mode.
    FT-8 works perfectly on all bands. Calls don't show up on he band activity screen but activity can been seen on the water fall
    Thanks Frank
  • Erik Carling EI4KF
    Is he really in Hound mode or has he put WSJTx in Fox mode?
  • W0QC
    W0QC Member
    It was in the Hound mode for sure. I'm aware of the difference. Thanks for the response
  • va7qi
    va7qi Member ✭✭
    Try using Fake It in radio settings in wsjt-x.
    73 de va7qi, ....Erik.
    You may wish to ask the WSJTx developers.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Fake it plays no role with a flex. It’s purpose in an analog radio is to move the transmit frequency to the center of the transmit pass bandwidth. The flex pass band is flat, so no change using fake it.
