Does your 6600M (or 6400M) display keypad like to play "hide & seek"?
[{"insert":"I guess no one else is having this problem. Must be my radio. Time to open my first ticket for the 6600M. \n"}]0
Same problem here with my 6400M, very occasionally the text input window will try to pop up but just not make it, I repeat until it does, I also use a cheap stylus which I find much better than my **** fingers.
73 Mike
...weird, I typed the word f a t and the comments appeared as **** - is this some kind of auto moderation thing?
Just checked and my 6600M also does the same. You have to "catch it" just right to get the keypad to come up. I think it is just a foible of the internal software, and it does not really bother me as long as I am aware and can overcome it.
And yes, Mike, big brother is always watching!!
I think it's safe to say that there is indeed some kind of software "bug" that needs to be fixed eventually. Flex, please review. Thanks!
Flex does not generally monitor this forum looking for issues (even though Mike, VA3MW does occasionally convert forum posts into helpdesk tickets). The best way to get action is if everyone having the problem submits a helpdesk ticket individually.
Agree...thanks, Len. Hopefully Flex will see this and actually already knows about the issue.
Well, that was the point of submitting a ticket... If folks experiencing the problem all hope someone else submitted a ticket, Flex won't be aware or will assume it is a one-off problem.
I found a video demonstrating a workaround for this issue. Basically instead of just tapping on the text field you want to change, tap and swipe just a bit.
https://youtu.be/f8t5CP_EYb40 -
Thank you. I will try this and report back.
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
