Memory Channels on Startup
Is there any way for me to NOT have my memory channels show up when I begin Smart SDR?
  • Patrick
    Patrick Member ✭✭✭
    Go to memory and delete them…. Delete any profiles that you do not want…. Make sure you export or they will show up again next time you import profiles.
  • J.C. W4QK
    J.C. W4QK Member ✭✭
    Hello Cy,
    I use a Flex 6400M and my memories do not show up when I start SSDR. However, if I have the memories window open and do not close it before I exit SSDR, the memory window will come up when SSDR is started. If that doesn't solve the issue then maybe there is problem with the SSDR version you are using.
    73 - JC
    W4QK
    Cy, can you share a screen shot please.
    I never seem memory channels show up unless I go find them, so I want to see what you are seeing.
  • Cy Stanway
    Cy Stanway Member ✭✭
    Now it stopped doing it! Go figure!
