Copying slices
Thanks for help.. best 73
Alessandro I2SVA
Click on the "Split" button in the slice flag. It will open a second receiver, same mode and settings, but higher in frequency by an amount appropriate for the mode, e.g. 1 kHz higher on CW.
73, Craig KØCF
Hi Graig,
thanks for the explanation, that is fine (if you assume that only one panadapter is open), but does not fit my behaviour.
Let me explain better: I have a 6400 (2 slices) and I am used to have always two panadapters open on 2 different bands (i.e. FT8 DIGU 14.074 and FT8 DIGU 21074). The two slices feed two WSJT-X instances and I am happy to listen to two different band, etc. :-)
Now assume that you see a nice CW (or SSB) spot, where the DX station is working split. You now click the DX spot and the active slice change frequency and mode; by using your suggested solution, you have to close the second panadapter and then click the split button.
I was looking for a simpler way that in a single click (or macro or Elgato call...) change frequency, mode, filter BUT to second slice that is already opened in a second panadapter.
Hope it is more clear now..
Best 73
Alessandro I2SVA0 -
If you have a 6400M or 6600M, the A>B button on the front panel copies the settings of the A slice to the B slice.
Hi Neil, this is fine, but I have a 6400 and I am looking for a A>B feature..0
You can use FRStack. With your 2 slices already open, FRStack has a "Copy To" function in a right-click menu that puts everything from Slice A to Slice B.
This is interesting, thanks" Now I wonder how the FRStack command "Copy to" can be automated either with an FRStack macro or with an Elgato command... Anyone can please help?0
I think that the only one who can help is the FRStack author. It seems to be that there is no way currently to action this function in Stream Deck as the required command is not part of the REST protocol. So you could email him but I did that myself a week ago on another matter and did not receive a reply. So he might be away or too busy at the moment. I use the right-click quite often to copy from one panadapter to the other so it would be nice to have a one button press in Stream Deck.
Will FRStack "Swap" do the task?
If so, you can make a hot key in FRStack for "Swap". Then, in StreamDeck, create a "hot key" button for the same set of keys you define for "Swap".
Alan. WA9WUD
Hi Alan, no it a is real swap and not a copy to. Copy to does the job (the command below Swap with in your picture. Whereas Swap can be programmed into Stream Deck, the Copy to function cannot it seems. For me using FRStack directly for Copy to is good enough but I presume for Alessandro there is not a visual on a computer screen and the Deck is at hand and is more convenient.
I did try a long winded set of actions programmed into the Deck. I sent the panorama A Slice to memory, then set panorama B Slice as active and intended to send that memory to that Slice. But I couldn't make it do that. Since we do not know how that Copy to function works, we are stuck.
Erik you are 100% right. I have opened a case with FRstack support, if there is a feedback i will share here!
tks, 73
alessandro i2sva
Hi all,
here below the very nice answer from Mark W3II about FRstacks Slice copy (A/B) feature:
FRStack does not currently have a hot key or REST API that exposes the Copy To functionality:
---Quote---
I will add this on the next release
-REST API will be as follows: note n is 0-7, x is A-H
-ActiveSlice/COPYFROM?param=n
-ActiveSlice/COPYFROM?letter=x¶m=n
-ActiveSlice/COPYFROM?index=n¶m=n
-Slice/x/COPYFROM?param=n
And
Hotkeys where “To” slice index x is 0-3 and “From” slice index y is 0-7
SCOPYTOx_y
73,Mark W3II
Well done Alessandro and thanks to Mark.
Erik.
Now implemented in FRStack, thanks Mark. Set it up in Stream Deck for easy one button press. Excellent.
Thanks Mark for this new set of features!
_____________
Quote from Mark:
I have uploaded a new version of FRStack. V3.1.34.63 which adds the Hotkeys and REST Slice COPYFROM COPYTO commands.
I also updated the Stream Deck sample that is installed to FRStack’s directory showing these commands.
These are found under Radio, Slice, Slice Swap folders.
The details are documented in the Help, View REST help.
Old thread but does this function still work? I have been unable to get it to swap. Copy to works but swap is not changing slices. I am running smartlink if that matters. I need to test locally.
I am not running Smartlink so I can only comment that Swap works locally.
This is the most simple scenario with only two Slices which swap.
Erik
- 109 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
