6400M set up with ac log and wsjt for Boy scouts in the field. Help Needed
Our group N9WH ARC is helping out with a Scouting Camporee, We have been asked to show 6 different aspects of ham radio to them.
I picked the task of FT8 and logging with AC log. I have gotten it to work with very inconsistent results, Being if i get it running and connected it never comes back after i turn off the radio or the laptop. I document all my settings and when i go back to reset them sometimes it works and other times its a 6 hour test of my patience.
the radio is plugged into the laptop directly nothing else not even wi fi
Ac log set to flex radio for rig
Ac log set to API interface port 2337
IP 224.0.0.1
WSJT setting to HRD 127.0.0.1: 7831 (I believe i need this for DM780 to run as Slicemaster is used.
Reporting is Accept UDP requests 127.0.0.1 port 2237
Notify on UDP request checked
Accepted UDP restores window checked
The above are my settings. Does not work all the time and i think I have a major problem with this set up. Any suggestions and or solution appreciated.
Thanks in Advance, Gary W9GD
You do not mention the radio ethernet setup. If you are connected directly, radio to PC, you should have both set to “Obtain IP adders with DHCP” (i.e. automatically). This will provide self-assigned IP addresses to both (169.****.****.****) - the two devices radio and PC will then talk to each other. For your other tools that need to talk to the programs, do use 127.0.0.1, loopback.
All of your interaction with the radio will be through DAX and CAT, and they know how to talk to the radio. Should be bullet-proof.Good luck with the Scouts, Gary.
You should use Flex API to communicate from AC Log to the radio instead of Flex Radio and COM port.
Ted, Dave,
Thank you both for your input. I did try the Flex API again last night and worked great. I tried that in the past but overlooked after changing a setting in AC you must reboot for the changes to take affect.
Tested radio to ac log to ft8 many times last night from a cold boot and everything is working great !
AC log set to flex API
WSJT rig control set to none.
WSJT IP 127.0.0.1 Port 2237
Slicemaster and /or Dm780 not needed. I am not a guru when it comes the background interfaces but everything is working great.
I took screen shots of every setting so if anyone needs them in the future please e mail and you can save a whole lot of time.
Thanks much the Scouts will enjoy text messaging over the airwaves.
Gary W9GD
Gary, if you’d really like text messaging over the air, install JS8Call - now that’s sophisticated text messaging with relay and store-and-foward. It’s based on wsjt-x, and uses FT8 encoding, but long messages. Just google JS8 or JS8Call.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
