Memory Channels on Startup
Cy Stanway
Is there any way for me to NOT have my memory channels show up when I begin Smart SDR?
Go to memory and delete them…. Delete any profiles that you do not want…. Make sure you export or they will show up again next time you import profiles.
Hello Cy,
I use a Flex 6400M and my memories do not show up when I start SSDR. However, if I have the memories window open and do not close it before I exit SSDR, the memory window will come up when SSDR is started. If that doesn't solve the issue then maybe there is problem with the SSDR version you are using.
73 - JC
W4QK
Cy, can you share a screen shot please.
I never seem memory channels show up unless I go find them, so I want to see what you are seeing.
Now it stopped doing it! Go figure!
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
