Spots settings window not propagated
When trying to open Settings - Spots the window opens but its not propagated (display just a think empty window. SmartSDR 3.2.39.
[{"insert":"I have the same problem exactly. Is there a fix for it?\n"}]0
AB5XS LA4XLA. Havent seen a fix for it yet. It works fine on another computer with a fresh install av Windows.
Uninstall new install of Smart SDR does not fix it. I think it must be some settings left in the registry, either under "Local Machine\Software\Flex..." or "Current User\Software\Flex..."
Uninstall SmartSDR, Reboot, and delete any leftovers in registry. Then do a new fresg install Smart SDR.
I will have the "problem computer" by hand coming weekend so i caninvestigate and see if i can find the specific setting hat leads to this window behaviour.
I will post back if i find out.
73.
[{"insert":"Reset the SSDR.settings file on your PC"},{"attributes":{"header":{"level":2,"ref":""}},"insert":"\n"},{"insert":"If SmartSDR for Windows is running, close it down."},{"attributes":{"list":{"depth":0,"type":"bullet"}},"insert":"\n"},{"insert":"Then enter "},{"attributes":{"bold":true},"insert":"%APPDATA%"},{"insert":" into the Windows Search box. It will display a folder as a result of the search. Select the folder."},{"attributes":{"list":{"depth":0,"type":"bullet"}},"insert":"\n"},{"insert":"If you are presented with a set of folders of which one of them is "},{"attributes":{"bold":true},"insert":"ROAMING"},{"insert":", select that folder."},{"attributes":{"list":{"depth":0,"type":"bullet"}},"insert":"\n"},{"insert":"You will see a"},{"attributes":{"bold":true},"insert":" FlexRadio Systems"},{"insert":" folder listed. Double click on it to open the folder."},{"attributes":{"list":{"depth":0,"type":"bullet"}},"insert":"\n"},{"insert":"In that folder is a file with the name "},{"attributes":{"bold":true},"insert":"SSDR.settings"},{"insert":". Delete that file."},{"attributes":{"list":{"depth":0,"type":"bullet"}},"insert":"\n"},{"insert":"Restart SmartSDR for Windows."},{"attributes":{"list":{"depth":0,"type":"bullet"}},"insert":"\n"},{"insert":"\n"}]0
ab5xs-
Off the subject, but what is the formatting in you last comment? I've seen it before in other posts.
It is very difficult for me to read.
I copied from an email. I couldn’t figure out how to delete it.0
Basically he is suggesting to delete this file:
"C:\Users\UserXXX\AppData\Roaming\FlexRadio Systems\SSDR.settings"
This has bit me in the rear end a couple of times. I have now stored the f ix in Evernote amongst a number of other Flex fixes and work arounds.
edit: I had a question about this solution. But then found the same answer in a slightly less ambiguous form and from an unimpeachable sourse - Tim. Look here:🙃
If dont it had been. Open Chorme And Visit Afiyu Kent https://afiyu.net/
Website For More Details about this.0
- 633 The Flea Market
- 127 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 928 Genius Products
- 339 Tuner Genius XL
