Tuning step change in V2.7.6
I have a Flex 6600M. Since I updated to V2.7.6, the frequency tuning step has changed. Now on AM, the lowest setting is 250. Can that be changed or is an update going to address it?
Gary
KG5CW
  • Neil D Friedman N3DF
    Neil D Friedman N3DF Member ✭✭✭✭
    In 3.2.39, the minimum step is also 250 Hz.
    edited October 2021
    You can overtype the 250 to anything you like up to 999K, followed by the enter key. It will stay that way until you change it by typing a new value or by clicking the value change arrows. If you set it to 100 Hz, then change modes, when you come back to AM, it will still be 100.
  • Gary
    Gary Member ✭✭
    The 6600M screen does not allow you to enter a value.
    Hi Gary, I wonder what would happen if you used a computer to change the value, close the slice, then open the slice on the front panel? I don't have an M model or a Maestro, so I can't try it myself.
