Looking for a Flex-6600 owner in the Lake Placid, Florida area
Dewitt
Dewitt Member ✭✭
edited October 2021 in SmartSDR for Windows
I would like to find a local Flex owner to install firmware in my Flex-6600M. I am in an assisted living facility in Lake Placid, Florida and do not have access to the facility's router to properly install firmware updates. Restrictions and spouse support impedes my ability to leave the facility except for very short trips. Would like someone locally to pickup or I can drop off the Flex. Have the carrying case but would like to find someone so that I don't have to remove the Flex, power supply, cables, laptop, and key. I have both a Dell laptop running Windows 10 and a MacBook Pro running the Mac SDR software. Right now the rig will only run from either the Dell or the Mac but without a firmware update it will not run from the front panel as a stand-alone rig. Thanks in advance. Contact via k9foh1945@gmail.com. Cheers, Bob.
    Hi Bob
    Our support team emailed you Friday regarding this. Did you receive it?
  • Dewitt
    Dewitt Member ✭✭
    Not received
