Cannot access the remote 6400 via SmartLINK
Yoon HL5BLI
Member ✭
I cannot access the remote 6400 via SmartLINK.
I last used it on Sep 24th at 13:40 UTC.
After that, I logged out of SmartLINK and simply logged out without turning off the computer.
And today at 06:30 UTC, I accessed the remote 6400 via SmartLINK again, but I am logged in but not able to access.
Callsign, First Name and Last Name are blank, and Log Out below them is enabled.
I log out and log in again, but it's the same.
This is probably a problem with the Flex server.
Is there a way to use it without relying on a FLEX server to access the radio?
Look at Wolf´s page, there is description of how top set up "softether.net" . This works with SSDR and is 100% reliable and does not need any weird cloud services ( only some dyndns, wichh they usually provide via a japanese university, but anything else will also work ).
Harry DL9NDW
Hello, Harry
Thanks for the advice.
I was stressed out by this SmartLink.
If things go wrong, it's taking a lot of time because I have to get to the home where the Flex radio is installed.
I'll try your advice.
thank you.0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
