SmartLink Outage ??!!
Good Morning All
Is there currently a SmartLink Outage as in May 2021?
I was not able to logon this morning (25. Sept. 2021) to our remote DX-Station.
Yesterday evening everything worked perfect until 00:30.
73 de HB9RYZ, Wolfgang
  • Johan SE3X
    Johan SE3X Member ✭✭✭
    Just tried login in from SM country. No luck. Seems SmartLink is down.
    73 de SE3X, Johan
  • Wolfgang
    Wolfgang Member ✭✭
    I hope they will fix it asap. I guess the Cloud service for SmartLink Logon Authentication at Amazon could be down.
    73, WOlfgang
  • Johan SE3X
    I hope so to Wolfgang. Many relay on SmartLink and to make it worse, this weekend we have the CQ WW RTTY Contest.
    I'm working so can't participate. But if I should, I have VPN as a back-up and it is handy to have in this situation. Even though my hair turned white and grey when setting it up. Not an easy task even with a bit of network skill.
    73 and have a nice weekend!
    Johan
  • Bogdan SP8BRE
    Bogdan SP8BRE Member ✭✭
    edited September 2021
    :s W PL również nie działa SmartLink dzisiaj rano brak połączenia ze zdalną stacja powtórka z maja 2021 przykra sprawa . Mam nadzieję że awaria nie jest poważna.
    ! 73
  • Wolfgang
    Wolfgang Member ✭✭
    Hello All
    Does some have a easy to read manual how to setup the SoftEther VPN solution on a Raspberry Pi in order to use SmartLink?
    An instalation and operations manual how to install the VPN Server, the VPN Client and how the local network looks like at home and at the remote site where the Fkexradio 6700 is running.
    This would be a great help for everybody and Ham spirit to solv this nasty SmartLink Outage issue.
    I would also like to pay something for a good tutorial.
    Best 73 de HB9RYZ
    Wolfgang
  • Ha Gei
    Ha Gei Member ✭✭✭
    Wolf, i think the best manual is on your own website.
    ( or it at least was a while ago... )
    Harry
    DL9NDW
  • Wolfgang
    Wolfgang Member ✭✭
    Hello Harry
    Yes, but this is not complete and not really tested in the field. It was only running at home in test lab envirnoment.
    73 Wolfgang
  • Harry: Do you have a running RASPI based VPN remote connection to a Flex?
    73, Frédéric, HB9CQK
    https://hb9cqk.ch/
