Started UP "New" Flex 5000 using PowerSDR set up for FLEX 3000
Spiceman28
Member ✭
I've been running a FLEX3000 for many years but just acquired a used 5000. To try it out I just plugged the power in, plugged in the Firewire cable from the 3000 and then launched PowerSDR that was already on the desktop. It updated the firmware and EEPROM and then came right up. The 5000 has the 2nd RX and those controls came up also.
Question is, should I do a complete re-install of PowerSDR or is it alright to use the same PowerSDR install as I use for the 3000?
John / K7RLD
John / K7RLD
It should work as long as the computer recognizes your 5000's firewire connection (you can check with the Flexradio.exe utility). If BOTH radios are connected, it will give you a rig selection window to select which rig you want to connect to. If you are gonna use both rigs, I would (first) save the database you set up for your 3000, and then once you connect to the 5000, make the changes you want to suit the 5000, and save that. Then you can load the configuration when you use each rig.
Charlie KB8CR
[{"insert":"I went through the exact same situation/transition a few months ago. No need to reinstall. KB8CR's comment re the selection window is correct. It should work fine. NY2A\n"}]0
For the most part it did work. But, two things in particular, didn't work properly. 1) When I would drag the panadapter or use my DJ Console to change frequency, the screen would freeze and then come right back to normal when I stopped dragging or turning the DJ Console.
2) The visual noise floor on the panadapter screen would pop up almost twice the height for a few seconds and then go back down; but audibly, no difference took place. Not to be confused with a static crash.
So, I've gone back to the 3K and everything is working normal again.0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
