Radio internet NOT available :(
Serial: 1021-1104-******, Max Licensed Version: v3,
Radio ID: 00-1C-2D-05-1A-C0, Radio IP: 192.168.1.219,
Radio Internet: NOT Available,
Radio Firmware: v3.1.12.51
I sign in to smartlink , i am trying to do the PTT registers the radio i keep getting radio internet /NA
I have the port forwarding set up from the 6500 same IP .
I need little help . I can connect via my ipad and iphone in the house , but not showing up on the internet outside the house network .
do you have any ideas before i do service ticket .
  • W7NIK
    W7NIK Member ✭✭
    FIXED it , gateway was wrong
  • Robert P.
    Robert P. Member ✭✭
    what was wrong with gateway?
    If you hard code your IP address you could make a mistake on the GateWay IP setting.
