NodeRed nodes for FlexRadio (without the need for extra software)
I've been working on some easy to use "nodes" for NodeRed to connect and control the FlexRadio's. Most of the discussion is going on on groups.io where there is an active community of people using NodeRed with their radios (even... non-flex radios!). The above image is an example dashboard (web page) that shows some of the capability of NodeRed and the nodes in action.
If you are wanting to take a look and perhaps join in on the fun:
Groups.IO group = https://groups.io/g/nodered-hamradio/topics
GitHub page/source for the project = https://github.com/stephenhouser/node-red-contrib-flexradio
We are up to version 0.7, still in beta but getting close to something that could be called v1.0. I'm happy to entertain ideas on how to develop the nodes and underlying JavaScript code so it is as useful and easy as possible.
Stephen
Stephen has been doing nice work to streamline the ability to access the radio via the API in Node Red. We have a couple of flows that work with his nodes.
I am a total noob at node-red.
How do I get the flow to import into my newly-installed node-red?
(Node-red version 2.0.6; Node.js version v15.5.1)
Ken
e-mail me and we can set up a screen share. I can walk you thru the process.
Alan. WA9WUD a.alan.blind@gmail.com
Ken
I can do a screen share with you too if you like.
If you are wanting to install the nodes themselves, use the "Manage Palette" on that screenshot and then select the "install" tab and search for 'flexradio'.
If you are wanting to install some example flows, then that "Import" Mike shows, then select "Examples" and expand the "node-red-contrib-flexradio" item and there are some samples.
This video might help as well -- https://youtu.be/x9Ga6DZKIGI
I did a Zoom call tonight on basics of Node Red for Ham Radio. I am uploading it to YouTube and it will take a while to process the HD, right now only in 360P.
Here is the link. Hopefully in a few hours the HD rendering will be done.
I try to deploy the flow and am getting this error:
Flows stopped due to missing node types.
- amqp-server
But I can't seem to get amqp-server to load.....
I want to be careful to separate the incredible work Dave has in his flows from the base node-red-contrib-flexradio nodes (which are new). Dave uses a bunch more nodes in his flows and may have a number of other dependencies. The node-red-contrib-flexradio nodes are self-contained and designed to handle the lower level (lower level than Dave’s flows) communication with the FlexRadio.
Long post longer, I think that amqp-server might be from Dave’s flows and not from the underlying node-red-contrib-flexradio nodes.
I have not heard of amqp-server node.
Ken, the FlexRadio v9b4 flow on the Node Red Groups.io site in the file section under Flows by Type/radio/Flows for use with N1 SH nodes.
After you load the Pi with the OS and Node Red, the WiKi has a readme file with recommended additional nodes that are used in some of the common flows. It includes instructions on installing the nodes. Once you load the nodes stop Node Red by connecting via a terminal window or Putty and type Node-Red-Stop. Then restart Node Red by typing Node-Red-Start. Then load the flow.
The flow is designed to work with the new FlexRadio nodes version 0.77 or newer.
Hi Dave, et. al. I am starting my experiments by running Node-Red on my windows desktop.
I have been able to import the proper flow (s) and the nodes, etc. but nothing runs. it keeps giving me an error: Waiting for missing types to be registered: - amqp-server
I can't seem to find where this is and why it can't get going. But it is blocking my flows from running or begin able to open the Dashboard.
I am not sure which flow is trying to use that node. Doing a Google search this is what I came up with.
You will need to have NOM installed on Windows. Sorry I can’t be much more help but all of my Node Red work has been using a Raspberry Pi.
Dave
Found it! Deleted it! the Flow is running! Whoo Hoo!
I created and posted an Introduction and Overview of the node-red-contrib-flexradio nodes to give a brief overview of the nodes included, how to install, and the basics of how they are designed to work. I'll make some additional videos about each node and/or specific flow creation, like I did with the Discovery Dashboard video.
Intro and Overview: https://youtu.be/8TXno7R7i2Y
Discovery Node/Dashboard: https://youtu.be/H-ZRe6NGHHc
Very nicely done videos, Stephen!
Thanks Len. I kept messing them up in one way or another. Took something like 5-6 tries each :-(
Success in the end is what counts.
Hi Stephen, I was fooling around with Node-Red and got things working. One thing that I noticed is that you have to manually enter the radio IP address for meter, request, message, etc, even though the IP is known from Discovery. Is there a way to specify the IP gathered in Discovery so that it can be applied to the other functions? It seems like an input to these functions containing the connected radio would be handy.
Is there a way to look at / modify the code underlying the Node-Red code boxes? I also wonder what language it is written in (or does it have its own syntax and compiler/interpreter?).
Hi Len,
just wondering what use case for having IP set from the discovery packets? Also, what about multiple radios on the same subnet?
The only use case I could see is making things a little easier for single radio network where the router properly handles uPNP for SmartLink. My network has DHCP reservations for all major components (PC, radio, amp, tuner, antenna switch, etc). So doing a one time setup of the nodes in Node Red.
By the way on the Node Red groups.io site in the files section under !1!Files by Type/Radios there is a folder with flows designed to work with Stephen’s nodes.
Also, Stephen has done a great job in creating these dedicated nodes making parsing internal meter data easier.
Len,
I had considered the use case you describe, using the discovery node to configure the radio in the flow and see the appeal of a self-configuring system as you do. Ultimately, I decided not to implement it.
There are a few things working against the idea that brought me to the current design. I patterned the nodes on existing nodes in NodeRed (like the MQTT nodes) and these node do not have that type of auto-configuration design. I also consulted with Dave, Alan, and others using NodeRed with their radios (see Dave's note above) and no one seemed to think it was a strong use-case. Most folks have just one radio and can set a fixed IP address in their LAN for it. If you do have multiple radios, you would probably want to be certain which one you had connected to before sending commands to it. Lastly, I wasn't sure how I would accomplish it with any sort of stability given that discovery packets arrive continually. That is, does it constantly reset the connection? Would you have to put a filter node in? Would there be some form of special "reconfigure" node or a special command that does that reconfiguration?
I'm happy to keep the idea open and alive, but it's not on my immediate to-do list. There's a number of other changes, updates, and tweaks (and other projects) that I have in mind and feel like have more immediate uses.
The source for the nodes hosted on GitHub, written in JavaScript, with an MIT open source license. I'm happy to consider pull requests if you or anyone is so inclined. You can find it at https://github.com/stephenhouser/node-red-contrib-flexradio
I was thinking more of a global variable that could be used. If it was an array, you could do a radio chooser when there is more than one IP address in the array. If only element 0 is filled in, then just do the connect.
My current project (TeensyMaestro), just connects to the first radio it finds. If I ever get my hands on a second Flex, I will take the array approach and build in a simple radio selector screen.
I did a similar thing with multiple clients. My gizmo binds to the first client in the array. Then I have a menu that shows all connected clients and lets me select the one I want. That way in a multi-operator environment, the TeensyMaestro(s) will control the desired client(s). I was thinking along these lines when I asked my question.
Thanks for the info. I will take a look at GitHub to see what it all looks like. It was a stretch for me to learn C++ and use it in an Arduino environment after a lifetime of PL/I, Fortran and COBOL. I don't know if I will have the energy to jump into Java, but I am interested to see what is behind the scenes.
Your library of Flex functions is really great, and I was able to get a bunch of items working right away (including an S-meter). I got a slider to do volume, but I don't see a way to get control reciprocity (i.e. the Node-Red control follows the value of the SmartSDR control). The way I have it working is fun to see in operation, but not very useful in real life. I wonder if this is inherent in the design of the controls, or if I am just missing a step to get that to work.
Len,
I like the design you laid out, with an array or similar. In thinking forward to other ways I'm hoping to use the library, I might reconsider where this feature is on my todo list.
I have a few flows that control the audio level and power output in the way you describe. It follows the slice on the radio and you can adjust either in NodeRed or on the Radio. My intent is to make a video about building that flow in the near future. Essentially you have to bind to the client (I think you and I talked about this previously in another thread), then feed the messages from that slice into a UI component (for updates) and feed the output of the UI component to a request node (to change the value). The UI component has a checkbox (un-checkbox?) to avoid loopback problems.
Stephen
I just finished my multiplex Node - Red flow, and am able to comment on your plans to add audio controls.
Regarding audio type commands, the command must be directed to a specific slice (number 0 through 6). The commands use "set' which is a number derived from the order the client(s) was connected, then the order of pan adapters added, then last, order of slices added, then associated to the bound client.
This is where having the "msg.handle", included in each of the different Flex message packets, is very useful to set up these alignments. (so....do not remove the "msg.handle" message!)
>>>>>>msg.payload = "slice set " + slice_a_set + " audio_mute=" + msg.payload<<<<. where slice set is a number 0 to 6, and msg.payload is "0" or "1"
Commands that control the radio, such as Tune or MOX, go to the "bound client".
My plans were to do more testing and post my flows, when you send out Flex Node v1.0
Let me know if you want an advance copy.
Alan
Stephen
I just finished my multiplex Node - Red flow.
Regarding audio type commands, the command must be directed to a specific slice (number 0 through 6). The commands use "set' which is a number derived from the order the client was connected, then the order of pan adapters added, then last, order of slices added, then associated to the bound client.
Alan
Alan, et. al.
Good information about directing commands (like audio) to a slice. That's a problem for a level above my nodes.
...always happy to pass problems "up the stack" :-)
Stephen
Alan,
Yes on looking over your flow. You have my email address, send it along. Not sure when I will look at it, but it would be good to see how things have changed in your flows and how you are using things.
Stephen
pretty sure n1sh@arrl.org works too.
Hi Stephen, Thanks for the info on setting the sliders with info from the radio, I appreciate it. Am up camping, so I can't look at that further right now, but will do some more experimenting when I get back. I may get a Raspberry Pi and see if I can do some of the things with it and Node-Red that I did with my Teensy (Arduino work-alike) project. Dave and Alan suggested this a while back, but I was too preoccupied with the Teensy project to take on anything else.
Wolfgang,
I hate to drop a pointer to a different platform, but... there are a bunch of folks developing flows with these nodes over on groups.io
When you install the nodes there are examples included. In Node-Red check under "import" then "examples" and you should see the node-red-contrib-flexradio examples. They are a reasonable starting point.
I've also got a few videos on YouTube to get you started if you like videos:
https://www.youtube.com/playlist?list=PLFeSzqhDMutUQJwLXwDYo94M8RThH9I6U
Stephen
Hello All
I’m playing around with Flex Node Red flows from WO2X and N1SH and got some strange behavior with my Flex 6700. As soon I activate my Flex flows some relays in the Flex are going to start to click ON and Off and I had to shut down my Flex 6700 manually.
So I have no idea was is happening. So I guess, it is not so easy to understand the Flex flows. Last weeks I had to do a factory reset of my Flex after testing the Flex flows from WO2X.
Do you know more about this issue?
Best 73 de HB9RYZ
Wolfgang
Hello All
Actually you should be able to take over out-of-the Box Flex flows and only enter the IP address of your own flex - and bingo.
This concept is working great for the KM-Tronic Relay etc.
What I need is just this Flex Flow for my Flex-6700
It would be great if you could copy and paste ready-made Flex Flows.
Or do I see this wrong?
Not every HAM has time to deal with Node Red in detail.
73 de HB9RYZ
Wolfgang
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
