an anyone tell me if the Jetstream JTPS32MAB works with the 6600M
angelo
Hi Flex Community,
Does anyone know whether this power supply will work with the Flex radio 6600M?
Thanks, Angel
Thanks, Angel
That is a 30 Amp surge, 25 amp continuous power supply.
You should be fine. If you can pump it up to 15V even better.
Hi Mike, I just bought the radio, and I didn't buy a power supply, but I have the Jetstream which I use for my VHF/UHF rig, what power supply would you recommend to work great with the 6600M? Thanks...0
Angelo, I use a mfj 4230 which is equivalent to your jet stream, same ratings, same voltage adjustment, meter selections. I adjust the output voltage to 15 volts to get 14 volts at the Flex at 100 watts transmit power. The combination works flawlessly. I have other 4230 supplies on other radios, all trouble free. The one you have will serve you well.
- 387 Community Topics
- 156 SmartSDR+
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 970 Maestro
- 944 Genius Products
