WiFi plug 220V
I would like to purchase a WiFi plug so that I can switch off the power supply with the app. I have flexradio 6500 would give this problem that I turn off diamond power supply without turning off the flexradio first.
  • Dennis Wage
    Dennis Wage Member ✭✭
    Although not ideal, I am fairly sure that Flex designed radios to lose power and be ok.
  • Stan VA7NF
    Stan VA7NF Member ✭✭✭
    I have not tried this but:
    What about a relay on the diamond input power that opens the flex power on/off lead and, if the 12V decay is too fast to also have a small electrolytic on the 12V flex power. Could even be put inside your power supply.
  • Pat ON3CQ
    Pat ON3CQ Member ✭✭
    Thanks for the tips, I'll check with the shop here. The relay option would be useful.
    73 Pat
