Profile List API Command
I have not been able to find a list of profiles using an API command.
I did find the mic profiles were included in the "sub radio all" packet, but nothing for the other profiles.
The wiki implies there is a command "profile <type> ???" command, to get profile info, but the wiki does not give any details.
Need help... Can anyone share the API method, sub or command, for getting profile lists?
Alan. WA9WUD
The commands to obtain profile information taken from FlexAPI
profile global info
profile tx info
profile mic info
profile display info
Hi Alan, that tripped me up for a long time... I eventually figured it out. I am on a road trip getting home late tonight. I will post the profile API command when I get up tomorrow.
Now that I am thinking about it, you might want to try profile list or profile list all. I will get you the actual commands tomorrow.
You need to bind to a GUI client to activate a profile, so I can give that to you as well. If you just want the list, then you don't need to bind to a GUI client.
Tried "profile list all" and "profile list". Did not work.
How do the developers know the commands? There is nothing in the wiki on getting a profile list!
Alan
Yep, a definite hole in the documentation! Sorry my memory is so bad... (maybe sub profile all???) I do have it working reliably and can even tell which profile is currently active.
I will be interested to see what you are doing. You, Dave and Mike have done some really creative things with Node Red.
Thanks, Mark
I have enough to work on my profiles. My primary continues to be FRStack for profiles, but I wanted to make my own too.
What I found:
- "profile global" response received
- "profile tx info" no response, but, tx profiles were in the "sub radio all" vita49 packet
- "profile mic info" response received
- "profile display info" no response
I am good for now.
Alan. WA9WUD
- 375 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
