Profile List API Command
Alan
Alan Member ✭✭✭✭
I have not been able to find a list of profiles using an API command.
I did find the mic profiles were included in the "sub radio all" packet, but nothing for the other profiles.
The wiki implies there is a command "profile <type> ???" command, to get profile info, but the wiki does not give any details.
Need help... Can anyone share the API method, sub or command, for getting profile lists?
Alan. WA9WUD
  • Mark_W3II
    Mark_W3II Member ✭✭✭
    Answer ✓
    The commands to obtain profile information taken from FlexAPI
    profile global info
    profile tx info
    profile mic info
    profile display info
    Hi Alan, that tripped me up for a long time... I eventually figured it out. I am on a road trip getting home late tonight. I will post the profile API command when I get up tomorrow.
    Now that I am thinking about it, you might want to try profile list or profile list all. I will get you the actual commands tomorrow.
    You need to bind to a GUI client to activate a profile, so I can give that to you as well. If you just want the list, then you don't need to bind to a GUI client.
  • Alan
    Alan Member ✭✭✭✭
    Tried "profile list all" and "profile list". Did not work.
    How do the developers know the commands? There is nothing in the wiki on getting a profile list!
    Alan
    Yep, a definite hole in the documentation! Sorry my memory is so bad... (maybe sub profile all???) I do have it working reliably and can even tell which profile is currently active.
    I will be interested to see what you are doing. You, Dave and Mike have done some really creative things with Node Red.
  • Alan
    Alan Member ✭✭✭✭
    Thanks, Mark
    I have enough to work on my profiles. My primary continues to be FRStack for profiles, but I wanted to make my own too.
    What I found:
    • "profile global" response received
    • "profile tx info" no response, but, tx profiles were in the "sub radio all" vita49 packet
    • "profile mic info" response received
    • "profile display info" no response
    I am good for now.
    Alan. WA9WUD
