SW3.2.39, FLEX6600M doesn't free the BIT cable output after power off
I'd brought it up earlier but never got a useful reply. With upgrading to 3.2.39 our 6600M still has the band information of typically the last used band or 80 m on the output of the BIT cable. This way the antennas are not released for other radios or to be grounded. it wasn't the case with earlier versions. Power Off means by front button only. 12 V dc supply is still connected. Is there a plan to sort this bug?
Another issue with 3.2.39 is that the 6600M now doesn't boot up automatically and requires inputs on the screen to chose operate and later SW version. That kills our remote capability.
Any tip/hint would be appreciated.
73 Holger
On the version chooser screen, touch the little gear in the lower left of the screen, then enable “auto connect.”
Thanks Neill, that worked. When I enabled "auto connect" I had to switch off the radio as it was stuck and would not start on its own.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
