I just received my 6400M today. What should I do after I take it out of the box?
I just received my 6400M this afternoon. I would like to take it out of the box, put the unit where I want it, connect the antenna coax, receive antenna, power cable and ethernet cable. What's the next step after this? I did watch a video that showed updating the SSDR within the 6400M. But after that, is there any crucial that I need to do?
Thanks!
Mark Griffin, KB3Z
Yes, get it on the air!
You will probably want to register SmartLink so that you can use it remotely, but that is not strictly required.
Setting up your TX equalizer is another good thing to do at this point. Ken, NM9P has a set of really good videos on YouTube. He shows you how to use Full Duplex mode to really get great sounding audio from whatever mic you use.
In addition to what Len has recommended, if you haven't done so already you will want to get on the FlexRadio web site and download all the documentation. To find it, at the top of the Flex home page click on Support, then Documentation. You can select the type of documents you want both at the top and left side of the Documentation page. You will want to get the User Guides for the 6400M and 6600M radios, as well as the SmartSDR v3 manual. There are many others that you may find useful as well.
Welcome to the FlexRadio community!
73, Craig, KØCF
Plug a large monitor into the HDMI slot on the back of the 6400M.
Guys,
I have it working. But I have a footswitch that I would like to use so I can key my microphone. Where do I connect that to?
PTT connector (RCA type) on the back of the radio.
My footswitch has a 1/4 phone jack at the end of it. So I should purchase a 1/4 mono jack to RCA plug adapter.
RCA plugs are among the easiest to solder. You could cut off the phono plug and solder on an RCA plug.
Some would say RTFM. But GL & 73.
You can order a 1/4” stereo jack to dual RCA male. Plug your foot pedal in the jack and one of the RCA plugs will plug into the PTT jack. I forget if it is right or left channel RCA. Try one, if it doesn’t work, use the other. Or as Neil said, if you are good at soldering you can change the plug.
David,
I will be connecting my Microphone to the microphone jack on the back of the 6400M. Wouldn't I need just a 1/4 inch jack to RCA for the PTT?
Mark KB3Z
Yes, if you really don’t want to solder an RCA plug. Suggest you read Sec 7.4.5 and 7.4.18 in the 6400M/6600M User Guide.
- 384 Community Topics
- 646 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
