Should the power button stay illuminated on my 6600M after installing a GPSDO?
Best Answers
Yes. The colours are explained in the SmartSDR manual, but as long as it is getting a valid GPS signal, you will have a Blue button.
• FLASHING GREEN: Radio is starting or shutting down
• SOLID GREEN: Radio is in receive mode
• FLASHING RED: See Error Conditions below
• SOLID BRIGHT RED: Transmitting on PA
• SOLID DIM RED: Transmit engaged, but transmit interlocks are not ready. Refer to the SmartSDR documentation for description of the transmit interlocks.
• SOLID ORANGE: Transmitting on XVTR port with low power
• SOLID PURPLE: Radio is performing a software update
• FLASHING WHITE: Radio is performing a reset to factory defaults
• OFF: Radio is off
When the optional GPS Disciplined Oscillator is installed:
• SOLID AMBER: Radio is off, GPSDO is powered for stability
• FLASHING YELLOW: GPSDO is warming up
• SOLID YELLOW: GPSDO is “holdover” mode (has lost satellites)
• SHORT FLASH BLUE: GPSDO is locking
• LONG FLASH BLUE: GPSDO is in “hold phase” mode
• SOLID BLUE: GPSDO is locked
Thank you Mike. I had only read the installation instructions and the 6600M manuals.0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
