Send Spots to MacLoggerDX for Alerts
I am moving from Windows to the Mac platform and am trying to use the native SmartSDR for Mac FT8 tool (instead of WSJT-X/ JTALERT).
Is it possible for SmartSDR Mac to send spots to MacLoggerDX so alerts could be generated for missing DXCC entities?
Thanks, Ron K2RAS
hi ron
The way JTbridge works is its listen to UDP broadcast from WSJTx each receive cycle of FT8. It then looks at preference selected and then check current log of macloggerdx (mldx)...then within its display hilites hits defined by the preference. So there is no need to send data to mldx spots. it doe sit own spots alerting based on jtbridge preference.
For example. YOU ARE HUNTING FOR NEW COUNTRIES TO WORK.
SET JTbrdige the way i have shown above. JTbrdige display will hilite in RED any country you dont not have confirmed. Then you can click on that line and wsjtx will be updated with the call and freq and be ready to transmit on next FT8 transmit cycle.
When you work that station and time to log it, jtbridge handles the handshake and send the data to mldx for logging when you click log in wjstx. Totallly seamless
AND
TO KEEP THE LIST IN JTBRIDGE TO MINIMUM
then set Filter preference as follows
this will keep jtbridge from showing anything you have already confirmed....
using these features i am one away from DXCC HR
and
have worked and confirmed 48 states on 6m in this past year
and
now have 52 countries including Japan on 6m
AND
there is a feature in mldx that tells mldx to listen to wsjtx UPD broadcasts
which is what you initially asked about....it fllls up the spots with wsjtx data directly
BUT
i dont know it FT8 app of the macssdr sends UPD Broadcast like wsjtx
i do not run macssdr as i have 6600m and use wsjtx and xdax and xcat
i have run 4 slices of FT8 on four different band
and
have run on 6m both FT8 and msk144 on two slices
and
even cw skimmer with extra-cluster ( a mldx addon) to send cw spots from 6600m to mldx
all of this helps hunting dx
i found this not to be all that helpful
and
prefer using jtbridge cause you can operate wsjtx by simply clicking on the item in the jtbridge list
hope this helps
Paul K3SF
It would be nice. I do miss the interaction between my logging app RumLogNG and WSJT-X. But I like the way the built in FT8/FT4 application works.
You could email the Author of Mac app directly and ask him about it. I have asked questions directly to him before.
Michael, AA5SH
you can use JTBridge with WSJTX (FT8Mode)
JTBridge interfaces with macdxlogger for logging and log information
In
the preference panel of jtbridge you can select 'not confirmed' and it will notify you
in pic it show i have select dx entity ans states..this lets me be notfied of needed state sfor WAS
and dxcc entities for dxcc
flooding macdxlogger with FT8 data is waste as you wont be able to keep up with it being updated every 15 seconds
Paul K3SF
ps website for jtbridge
Thanks for the response Paul. Just confirming, will JT-Bridge transfer spots from SmartSDR for Mac (not WSJT-X) to MacDXLogger. Also, in my case the number of alerts would be small as I am working for my DXCC and already have 900 entries.
Thanks, Ron
I guess I will have to stick with WSJT-X on the Mac. I had hoped to move to the native SmartSDR for Mac FT8 tool but the options for integrating selective alerts just isn't there yet.
Thanks for all the comments, Ron
- 385 Community Topics
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 962 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
