I need instructions on how to connect an external cw keyer to a Flex6600M
Hi Rodney, just connect a 1/8 inch plug from the paddles or an external keyer to the key jack on the back of the rig. If it is paddles, select Iambic, if it is a keyer, turn Iambic off.
This screen is from SmartSDR, so you will have to look in the manual to find the corresponding control for your 6600M if you want to use the front panel. Note that you need to be in CW mode to change this parameter.
From Sec 20.5 of the 6400M/6600M User Guide (“How to connect an external keyer using the accessory connector”):
In CW mode, the Key input on the FLEX-6000 rear panel accessory connector (pin 4) can be used as a straight key input. This is useful if you wish to attach an external keyer, such as a K1EL WinKeyer, microHAM microKEYER, or another contest-oriented interface. This input is always active and is not affected by internal keyer settings. It’s therefore possible to use both the external keyer and the internal keyer at the same time.
Thanks for all responses to this question, I will try implementing the accessory jack solution as this lets me still use the built in keyer in 6600M.0
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
