maestro not connect via Lan cable
Greetings guys .. I have my teacher he connects via WIFI but when I connect it by direct lan cable to my router or switch, he does not see it, it says Network unavailable, any idea that this issue may be, the lan cable is not I have changed the switch does not work perfect with my other flex, I am all heard thanks.
jim KP2B
Excellent!! I am glad that you got it working.
Hi Jim, it could be a bad cable, a bad switch or a bad router. To troubleshoot, I would start by connecting the Maestro directly to the radio using the LAN cable that you are nat able to connect with. You will need to restart the radio and restart the Maestro.
If it works, then the cable is probably OK. If not, the problem is most likely the cable.
If it works, plug the Maestro and radio into the switch without the router. If this works, then it is most likely the router.
If the switch is OK, then (if you can) plug the Maestro and radio into the router without the switch. If this does not work, then it is probably the router.
I suspect the cable or the switch, but you will need to test to be sure.
I hope this helps.
ok my friend if I did all that and then I gave a new reset and everything returned to normal thanks for the suggestion ... very happy now..lol 73
Not the issue in this case, but if you power the Maestro from the USB battery, the LAN connection is not available.
Chuck thank for answer I fix ready now is ok and working perfect....tnx and 73
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 966 Maestro
- 938 Genius Products
