DSTAR, FLEX has left me
FLEX WAVEFORM software is a great idea. FLEX had a DSTAR WAVEFORM software, installation, and operating documentation in the download for years.
With SMARTSDR version 1.5xx and the purchase from FLEX of a DV USB dongle and the DSTAR WAVEFORM software you could do DSTAR on HF or if you had 2m and 440 transverters do DSTAR on your local repeaters. Worked great. No bad issues with it that I could tell. I used my FLEX 6xxx on DSTAR HF voice and with the great waterfall, I could find a clear spot to operate.
With SMARTSDR version 2.4xx, the FLEX DSTAR Waverform software had a minor bug. It had a small delay that showed up in the next transmission. Minor, but a little irritating since I paid to go to 2.****.
With SMARTSDR version 3.xx, the FLEX DSTAR Waveform software was not even being recognized by 3.xx and would not work at all. And, again I paid for this "upgrade".
FLEX then removed any trace of the DSTAR waveform software and the instructions, and stopped selling the DV dongle. I had heard they were "sorta" working on a fix to this last summer, but "not their top priority".
I now have a ICOM 705 driving a ELECTRAFT KPA1500 at 400 watts out on DSTAR HF Voice. Great radio and amp. The water fall on the 705 helps on DSTAR. But not as good as the early version of SMARTSDR on DSTAR.
I remember a reporter asking a politician why he changed political parties. The politician said he did not leave the party... the party left him.
Kent,
Flex needs to get DSTAR capabilities back into their product. I would love to buy a transverter to get on our local DSTAR repeaters; however, this remains a dream.
Dave,
K5OZ
I just got a 9700. They better not do it too soon ;-)
I also have a ICOM 9700. Great radio for 2m,440,1.2ghz all mode and satellite work. I first bought a FLEX 660 and two transverters. This was still when the DSTAR waveform was working. The FLEX worked great on the local DSTAR repeaters and then thru reflectors.
But, the 9700 does not do DSTAR HF Voice..
Question.
What is the functionality gained by having DStar on your Flex? I am exploring how to enter into DStar and have looked at DStar computer access from home and handheld transceiver when mobile.
Since the Flex and the computer are both "home" based, how does one compare to the other for functionality?
Alan. WA9WUD
If you want to try DSTAR, a USB DSTAR DV3000 AMBE stick is a cheap way to start. If FLEX ever gets the DSTAR waveform to work again, then you can plug it into your
flex. Then you can talk over RF.
What version did DSTAR stop working. Can we roll back to get DSTAR functionality?
It worked completely OK with the last version of 1.****. Starting with 2.**** it introduced a small lag. I think the last working version of SSDR was about 2.4x
[{"insert":"Any updates for DStar compatibility?\nthanks,\nScott\nW5SLS\n"}]0
Flex dropped support for both DSTAR and FreeDV so really don't think you will see it come back around until someone builds a API to an external device for DSTAR or like the FreeDV soundcard software.
Just my opinion but there you go.
Flex removed the FreeDV and DSTAR waveform files, the install instructions, and quit selling the DSTAR DV dongle a couple of years ago, when SSDR was "upgraded" and would not work properly with the waveforms. Flex had been working on and off with a couple of programmers to try and get them updated and working. Appears to no avail. Flex has to work on items that it's customers want, and they can make money on. During the past couple of months, Flex had other issues to resolve.
Interesting, in a presentation to QSO Today in the spring of 2021, Steve Hicks talked at length about how great the Waveform API was and used the FreeDV and DSTAR waveforms as examples. At 26:20min.
FlexRadio HF SDR as a Platform QSO Today - YouTube
Kent
KQ4KK
And the FT8 on the iOS version of the software is a waveform running in the flex.
One thing to remember the API's for D-STAR and FreeDV where NOT written by FLEX and the problem was the D-Star dongle that was supported by the FLEX hardware became hard to get and as fast as FreeDV changes even today took a ton of work by the author of the FreeDV API to keep up with all the Mod compatibility updates with each other and decided to drop support for it.
I do miss the way FreeDV worked on earlier versions of SmartSDR, it was so seamless but it was a free API unlike D-Star if I remember right which was like $35.00, I can't remember exactly.
After no update support from the API authors for quite a while FLEX dropped support in SmartSDR.
Hope my memory has this correct but as usual I MAY be wrong Hi Hi.
The Flex DSTAR waveform was free. NWDigital is still selling the DVdongle.
I just watched Dan, N7HQ YouTube presentation on HF Station integration and Automation.
https://www.youtube.com/watch?v=T43PLcjvNmA
In an answer to a question about FreeDV and DSTAR waveforms. Dan said "they are working on it". But it will take a couple of more interations of software for it to work.
He said Annaliese McDermond, NH6Z is working on this issue.
I had been corresponding with Steve Hicks, N5AC over the past couple of years on the status of the FLEX DSTAR Waveform. However, he has not answered the last couple.... Will try to see him at Dayton/Zenia.
There is a rumour that if you take your DV Dongle and use a Quality Powered USB hub on the back of the radio USB port, it might work.
I have yet to give this a try, but if you want to give it a shot, I would be interested to see how it goes. (I can't just seem to find my Dongle) :)
Interesting Mike, I do have a powered USB hub ready to go with my ThumbDV dongle. Who knows where I put the last download of FreeDV as I've changed computers since then but I did manage to find FreeDV-0.97.0-win32 which I believe is not the waveform but an independent windows app. Does anyone have the latest FreeDV and the Dstar waveform to email me? ve3cko@interpc.ca
I hope Mike’s rumor is true! I will try to find my DVthumb drive and get a powered hub to give that a try.
Dave,
K5OZ
Anyone have available to send me, the FreeDV and Dstar waveform? ve3cko@interpc.ca
I'd like to thank Bret WX7Y for sending me the files. I did the install of both waveforms and see no FDV or DSTAR modes. It's been a few years since I had these installed and I followed the instructions, or so I think, lol. I do have a decent powered USB hub that I've been using with the DEMI 2MLDPA and had a couple of USB to serial converters that I used for band coding with the Quadra, and then the other went to the SDA-100 SteppIR controller.
Hi Mike I should have told you, Flex dropped support because the API's were NOT being updated, at least with FreeDV and with full software version it works great with the Flex just like any other Digital Program.
I thought maybe you was going to use it as a Start for some new API's I guess
Mike, send me an email. I might have them.
Does anyone have the last release of the Dstar waveform that they can send me? W5SLS@att.net
Thank you.-1 -
For the FreeDV side, we know that has been non-functional for many years.
There was a work-around that created that worked exceptionally well for about a year that we were using, that first used a raspberry Pi and later a Teensy module flashed with some FreeDV code to offload some processing, that was very nice for the last year. It allowed for TWO additional modes, as FDVU and FDVL. Supporting the latest 700D mode of FreeDV. And you no longer needed a computer, which allowed for operating FreeDV right from SmartSDR, as well as from an Ipad remotely with Smartlink.
However, after about the 3.3.29 release, it broke that functionality. :(
By broke, I mean it ONLY broke the USB side, and it still works on LSB, but the USB setting shows to be on USB but the radio remains on LSB when transmitting.
Certainly, the RIGHT answer would be to resolve the primary issue so there's no need to use a Teensy module at all. But since that doesn't appear to be in the priority list, it would sure be great to have the other functionality restored.
Walter/K5WH
- 339 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 172 SmartSDR for Maestro and M models
- 404 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 372 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 194 FLEX-8000 Signature Series
- 916 Maestro
- 888 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 744 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 963 Third-Party Software
