Flex USB port to Ciro Mazzoni ATU controller
I can not get the ATU controller to work in either full or semi auto mode . In manual it will select and tune. I am using the cable they sell for the Flex.
It sees the cable but doesn't appear to output frequency change as I tune the radio.
Settings are Cat, TX antenna, Ant2, Auto Report Enabled, Speed :9600 Bits 8 Parity none , stop bits 1
Flow control none.
Missing something ?
Thanks for any help
ED KM4HPN
  • Andrew Mitchell
    Andrew Mitchell Member ✭✭
    Have you tried using "Specific Slice" vs. "TX Antenna"?
  • MikeRuiz
    MikeRuiz Member
    Struggling with the same problem myself. Ticket in to Ciro. Already verified ATU2 firmware is on 4.06 which is required due to a flex cat change (per Ciro)
  • Anatoly Aranovsky
    Anatoly Aranovsky Member ✭✭
    I have the same issue. How did you solve yours?
