Flex-6400M and a tablet in the field
The Flex is able to recognize a direct link to a PC or Laptop but I will be using a windows tablet without LAN connector but only WIFI.
How would one create a connection between the transceiver and the tablet?
Any experience on this?
Didier (****) F6DXE
One possibility is to give your PC or laptop a USB LAN connector. I bought one on Amazon for 12 euro, works well. You can also get a Type-C adapter if that is the only type of USB port available.
Thanks for the tip, i'll check Amazon and I do have a USB port available.
BTW I will be using TM6JVX from the island of 'ile Vierge' in the north of Brittany on saturday the 24th of July.0 -
Another option is to bring a cable modem router with you that can create a WiFi network along with being able to plug the laptop and radio in via Ethernet. You do not need Internet to use the router. It will also be a DHCP server to provide IP addresses to the equipment.
Thanks guys, it was ok with the USB/LAN for all controls except the audio that I could not get properly.
THe DAX panel showed the signals coming in but FTDX and WSJTX reported error on the audio imput and I was not able to do FT4 or FT8 from the island.
Otherwise CW and all controls were ok between the 6400M and N1MM
I will try the router as mentioned by Dave
730 -
Oh dear, my laptop with USB LAN connector does get audio from the radio and is transferred to JTDX. I hope you were using the correct input. You would think that if DAX showed signals they must have been acquired though the LAN and must be available for the FT4/8 software.
I did once try the router method that Dave mentioned. I did not give it as an option because in my case it got affected by RF. You will have better luck, I hope.
Hi Erik, the DAX panel showed signals but nothing on JTDX. The chanel choice should be ok
I read somewhere in a group that JTDX should be started from N1MM which I did not do. I will try this
Didier0 -
Hi Didier, it is very strange. But as you know, everyone has a unique set-up and just because it works here is no guarantee it will somewhere else. For example, I have never had to involve N1MM with JTDX. I simply use the normal audio I/O DAX RX 1 and DAX TX and it sends and receives on the laptop. I presume your JTDX was set to these streams. If so, something else is affecting it I would say - not that I'm any expert. I hope you solve it.
Erik.
- 337 Community Topics
- 605 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 401 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 185 FLEX-8000 Signature Series
- 913 Maestro
- 885 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 740 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 952 Third-Party Software
