How to disable VOX when using CW?
GM7VSB
My headset works fine in SSB modes with VOX and is perfect for serious CW sessions but when I remove it for a more relaxed CW experience listening on my speakers VOX activates TX.
The VOX button in SmartSDR is highlighted blue but the button is inactive in CW mode, so I can't toggle it off. If I switch to SSB and disable VOX, when I switch back to CW VOX is enabled again but the button is blue and inactive.
This happened in SmartSDR 3.0 and continues to be a problem after upgrading to 3.1.
How do I disable VOX in CW ?
After digging about I’ve finally found a way to disable VOX in CW.
If I swap mode to DIGU or DIGL then disable VOX it will remain off when I toggle back to CW.
Interestingly if I enable / disable VOX in either USB or LSB it does not toggle off when changing to CW.1 -
Thank you your posts were helpful to me
steve
KG5VK
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
