Maestro intermittent audio transmit
Dean Davis
Member ✭
I have tried several PTT buttons on my Maestro (connected via wired network) to my flex 6600. I see the MOX light come on but there is no transmit audio. I am aslo using a Heil Proset Plus.
Hi Dean:
I'm assuming that the Mic is connected tot he Maestro. On the Maestro press the "MIC/SPEED' control. A menu will appear.
Verify that the "DAX is off" (lower left corner of the menu.)
On the left side of the menu verify that "M-MIC1" or "M-MIC2" is selected. Exit the menu.
If you need mic bias or the mic preamp select the "phone/cw" menu, those selection buttons are at the top of the menu.
Hope this helps
Gayle K0FLY
I should have added to select MIC1 or MIC2 which ever input the mic is connected.
Gayle K0FLY
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
