Maestro intermittent audio transmit
Dean Davis
Dean Davis Member
edited July 2021 in Maestro
I have tried several PTT buttons on my Maestro (connected via wired network) to my flex 6600. I see the MOX light come on but there is no transmit audio. I am aslo using a Heil Proset Plus.
  • K0FLY
    K0FLY Member ✭✭✭
    Answer ✓
    Hi Dean:
    I'm assuming that the Mic is connected tot he Maestro. On the Maestro press the "MIC/SPEED' control. A menu will appear.
    Verify that the "DAX is off" (lower left corner of the menu.)
    On the left side of the menu verify that "M-MIC1" or "M-MIC2" is selected. Exit the menu.
    If you need mic bias or the mic preamp select the "phone/cw" menu, those selection buttons are at the top of the menu.
    Hope this helps
    Gayle K0FLY
  • K0FLY
    K0FLY Member ✭✭✭
    I should have added to select MIC1 or MIC2 which ever input the mic is connected.
    Gayle K0FLY
