Maestro intermittent audio transmit
Dean Davis
Member ✭
I have tried several PTT buttons on my Maestro (connected via wired network) to my flex 6600. I see the MOX light come on but there is no transmit audio. I am aslo using a Heil Proset Plus.
Hi Dean:
I'm assuming that the Mic is connected tot he Maestro. On the Maestro press the "MIC/SPEED' control. A menu will appear.
Verify that the "DAX is off" (lower left corner of the menu.)
On the left side of the menu verify that "M-MIC1" or "M-MIC2" is selected. Exit the menu.
If you need mic bias or the mic preamp select the "phone/cw" menu, those selection buttons are at the top of the menu.
Hope this helps
Gayle K0FLY
I should have added to select MIC1 or MIC2 which ever input the mic is connected.
Gayle K0FLY
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 966 Maestro
- 938 Genius Products
