Wifi Web Antenna Switch
Mike-VA3MW
I saw this posted in eBay.
I have never tried it, but thought I would list it as an option. FRS is not involved with this in anyway, so you will need to do your own research.
I have been using this remote antenna switch for several months now and find it to be very convenient and well made. I placed the control box (for selecting the antenna) and a small 12 VDC power supply inside my NEMA 4 antenna cable entry panel outside my home. I mounted the the 6 position coax switching unit to a pipe below the entry panel. I control four antennas from my second floor radio room with my smart phone or my PC. The switch has a "Ground" position that will ground all antenna inputs. I run a Flex 6400M and an SPE Expert 1.5K-FA without any issues.
JC - W4QK
I've used the 4 pos switch controlled over the net for 6 months with no problem at the 800 watt level. I ordered the 7 position one for expanded operation. Please note that delivery is slow, Good price.
Bob W1CTC0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
