PGXL Fan revs to maximum 1 second every 2minutes
Mike Aust
My PGXL Fan revs to maximum for 1 second every 2minutes for most of the time while Amp is in Standby and Fan set to Standard Mode
Sometimes it less than 2minutes to cycle to get these 1 sec max rpm of the fan to occur
Is the temp too hot in Standby causing the fan to cycle on and off like this a lot
Sometimes it’s less than 2 minutes and fan spins fast but do not see any change in Standby Temperature
is there a bug in PGXL firmware 3.5.23 or is the PGXL at a critical crossover point in temperature at 36.7/39.1C inside the PGXL
Will try to get external fan to see if this behavior goes away !
Anyone else seeing this behavior ?
WB6DJI
-2
We are doing a lot of work on the fan management. A lot. :).
Keep an eye for the next update.
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
